RedTalon19
- Dec 10, 2000
Gigabyte GA-M770OT-UD3P
Phenom II x2 550 BE Callisto 3.1GHz
XFX Radeon 5770
8 gigs RAM (4x2gb)
2 HDDs
I just upgraded my system to the above but I'm still using an Antec 350w (model SP-350) PSU I picked up a few years ago from BestBuy. This PSU did not have the 8-pin 12V EATX connector but the mobo manual said it supported the older 4-pin so I tried it out and I'm up and running stable with this system so far. The BIOS reports voltages well within tolerable ranges too.
I run into problems when I attempt to unlock extra cores on my Phenom. I am able to post and enter BIOS but when Win7 attempts to load it either locks up or BSOD's. I am not sure if this is because the extra cores are bum or if the PSU cannot handle the extra load.
So my question is: should I upgrade the PSU even though I am currently stable? And, is it possible my current PSU is holding back my Phenom from becoming a quad-core or did I just get unlucky?
XFX Radeon 5770
8 gigs RAM (4x2gb)
2 HDDs
