cyberknight
- Sep 3, 2004
I'm not sure if I'm being paranoid about my temps or not, but I'm considering a hard drive cooler. How would I mount one on the Sonata consider it uses those drive cages? I notice a lot of coolers use 4 screws on the face of the hard drive, which happen to be the same screws that are used on the drive cages of the Sonata. I also don't want anything fancy, such as those LED viewscreens and what not.
If you're wondering, I do have a front case fan drawing air in, this one:
http://www.antec.com/us/productDetails.php?ProdID=75003
And I have both my case fans connected to the "FAN ONLY" connectors. (for quietness)
my system temp idles at 36 and HDD idles at 39 (in celsius)
I've seen my HDD go as high as 45 under load.
It's a Seagate 120GB SATA Hard Drive. Though, I hear that SATA's run a bit warmer than ATA's...
