Red Squirrel
- Nov 29, 2009
This seems like a silly question, and I figure the answer is no, but you know what happens when you assume.
Here's the scenario:
Say I have two networks, one is trusted, one is not trusted, we'll call them A and B.
If I have a PC with two nics, nic1 is plugged into network A and has access to all resources on that network. nic2 is plugged into network B, however that nic has no IP address assigned to it. It is used only to bridge to VMs.
Is that PC 100% safe from any dangers that may happen on network B, or is it at risk by being plugged in? This is assuming that no IP is assigned the nic itself and no extra protocols added like netbui or w/e.
I've been toying with the idea of adding a second nic to my server but not adding an IP to it and just using it for VMs to bridge to it. The fact that it's Linux is fairly safe but I want to ensure I'm safe even if there is an exploit, and a virus on network B. Network B could possibly even be a straight pipe to the internet. It's a network I tend to play around with depending on what I'm experimenting at the time.
