is it dead?
bbxrider
its an intel d850gb, in a clone thing
with memory in slots 1+2 it doesn't show anything on monitor, ie no bios
with mem removed, it beeps and no bios
with a bootable memory check cd in the cd, same thing, no bios
it has a floppy drive and usb ports on the mb, can i somehow try to flash the
bios with these?
:confused:
Are the CRIMM modules installed in the unused slots? Being dead is a possibility - no leaking or bulging capacitors anywhere on the board?
all the capacitors look ok,
the slots come in 2 pairs, i thought you only need a crimm if only using one side of slot
so i have 1+2 with memory and 3+4 are both blank, this is the way the pc originally arrived
and supposedly it was working at some point with just 1+2 occupied, i only have 1 crimm on hand, so will have to acquire a 2nd to fill both 3+4
