Is anyone having memory issues with A8N-VM CSM's?
Boltaction
Hello, I am building 14 machines for a client and decided on the Asus A8N-VM CSM for its DVI support and geforce 6150. After initially checking each motherboard with Kingston DDr400 matched 1GB pair and Athlon 64 3200+'s I began windows installation on while some installed windows, one or two gave me BSOD on CD loading, which I then used memtest86 and got errors on those builds within 10 minutes.
After this, I memtested 2 of the other machines and got errors within 30 minutes. I also noticed these issues:
The northbridge+sounthbridge were really hot
changing power supplies did not help, even to a higher wattage rating
changing memory helped but still gave errors
switching memory from blue to black slots did not fix errors
updating firmware seemed to help heat output
CPUs have not been switched out yet
One motherboard has run for 44 hours and has not had memory issues. It is using an allied 450 watt with latest stable firmware from US site, CAS latency forced to 3.
After forcing the CAS to 3 and leaving the rest as default, I get much less errors but they seem to be random. After 44 hours, one has 55 errors while another has 17 errors.
I am on the phone with asus right now. Also, the errors only happen over the 512mb mark. What the hell could this be, and is anyone else havking problems with these boards?
No memory related issues in a A8N-VM CSM build I did this past weekend. Using an Opteron 170 with Corsair TwinX2048-3200C2 memory. The mobo has 0702 as the bios revision. Memtest86 ran for a few passes without issue and two instances of Prime95 each exercising half of the available memory ran for 20 hours straight before I stopped it.
Hopefully you'll run across a solution. I also hope you don't hit a problem I ran into in that as soon as I installed the GPU drivers for WinXP, the output on the DVI-D port stopped and only VGA out worked. I can uninstall the GPU drivers but then that's not really an option. I haven't plopped a PCI-e video card which I know to be one solution but I'm going to replace this mobo with MSI's 6150 FID mobo and see what happens.
Ok, looks like switching to generic memory took care of the issue. Hopefully we won't have that DVI-D issue like you mentioned :( This is embarrassing for Asus I am sure since CSM stands for Corporate Stable Model. :p
