Is a upgrade required?
AliP
Just asking if this equipment setup is good.
Abit AV8
FX-55 Clawhammer cpu @ 2600 Non OC'd @50c
6800GT gpu @ Max OC
G-Skill Mem DDR400 2GB
Shitty CD drive
Lots of hard drives (database)
Audigi 2
550W psu
CMstacker case
19" Samsung Monitor [12x10]
Finally noticing a huge slowdown when playing games (the ones i can play) Rainbow 6 Vegas is at [10x7] Lowest settings @ 5-25 fps.
So the question is, is it time for an upgrade, want to play all the lates games at decent settings? Dont resist flaming this equipment. :)
Yeah well im running on AGP, so i tough if i had to switch gpu i had to get another mobo, and if it's at that level i could just do it all at once, any suggestions? I was thinking of somthing like that cristmas rig guy, toguh i am on a budget around cristmas :D
But nothing about the CPU? It failed some game reccomended tests but i guess a few high end Cpu's are clocked at low speeds, i cant oc it, its real hot already and its a clawhammer. A new 939 mobo and a evga 7950gt ko, would u reccomend that?
Well then you will want a 7900GS, it's AGP and a lot faster than the card you have.
Please check my edit, bump! ;D
Anyway, nothing about the monitor? And im just thinking of how long my rig will last until the next upgrade, is the 7900gs at that price the better choice in a price/time veiw?
Damn it! I cant find the card at Zipzoomfly and i cant use newegg, any ideas?
Woah, hang on a moment
The 7900GS is not AGP. It is PCI-E. The X1950 Pro, ATi's main competitor, is available in PCI-E or AGP.
If you notice a slowdown, its time for an upgrade. Unfortunately, you're on an AGP setup, which is a dead end. You should wait til you could upgrade the mobo/cpu/ram/vidcard... all your other parts look fine. Whats your budget? A core2 setup would run you about $550 without the vidcard.
i believe the 7800gs has an agp version. i would go with the x1950 pro (didnt know that was agp)
My options are:
1. Buy a 939 PCI mobo and a 7950GTKO card
2. Wait for the x1950pro at zipzoomfly.
3. Buy a new 775 mobo, e6600 cpu, oc memory, gpu and a big sata hdd. That'll piss me off.
I'm not on my own budget yet, daddy ;) figure out the rest.
So wich do you think ill benefit the most from?
I've benn aiming at 3. But it has a big price tag, maby just 2. and save for a big upgrade. And again i cant use newegg.
1. More thing, any difference between the X1950Pro 256MB and the X1950Pro 512MB in terms of performance?
