iPod mini 600mAh replacement battery question.
Celsius
As my friends and family know that when I buy something its an investment for me. Often I'll even wait a year or more to buy something. Example, I going to upgrade my p4 to a prescott I guess in may why well, Its a total pain in the ass to take out a motherboard and replace the chip and its going to be out than you might as well clean it too. (I have a high psi compress)
Anyway, a bit off track. So, I'm replacing my ipod mini battery from ths site. Its the best price and tools are included. My question is battery related, 600mAh is more mean that it holds a charge longer?
The 600mAH rating means that it will deliver usable voltage at 600mA for one hour. Or 300mA for 2 hours, or 100mA for 6 hours (not quite linear, but that's the idea). So a larger mAH rating indicates how long you can use it between charges.
Thanks, I was wondering about that. And, as always. I can get a honest answer. As I have told kyle before, if the forums gave stock advice I would be a millionare.
Something to think about people.
