Inwin Dragon Slayer m-ATX case
Definitely not my style in terms of looks, but internally seems to be pretty nice.
internally it is definitely nice, not sure about externally though still undecided.
Well, the "hip" look is a matter of taste. I think it's ok, but not spectacular. Design and features seem nice, but as Steeeeve pointed out, it's too big to really be a SFF case. My previous ATX case (NZXT Hush) was 42,8 liters while the micro-ATX SG03 is 22,5 liters. At 35 liters this case does indeed gain quite a bit of size compared to many other offerings.
Still, seems like a good option for someone who doesn't mind the size but also doesn't need a full ATX motherboard.
I was hoping this would be a bit smaller, but I guess sacrifices had to be made to fit the HD5870 in.
I would certainly be interested in a miniITX version of this though.
Holy crap, it's a Mini P180
Edit: Okay, so it's a bit different, but several interior elements match up.
Anybody notice the 5 expansion slots?
Anyone know if this can hold a 5970 or is it too early to tell?
Disappointed that the Lian Li V352 can't and unsure about DA Box as yet.
Lol, I'm a bit impatient sometimes! Should've let the page load first...
Ignore me :)
I'm in love. This thing is beautiful.
And it takes 2x 5970's Something I was hoping "Da Box" would do!
Its not a bad looking mATX case in my opinion. Plenty of good cooling looks like. Holds two 5970 is a plus as well. Taller and longer (depth) than my SG03 thats for sure but thats what you give up for superior cooling and fitting two 5970s adequately.
I have one. Love mine. It's the case for the Primary rig in my Sig.
Anyone know if H80 would fit on the top of this case?
According to the NE posted reviews one person has a H70 installed in his rig and another user has a Noctua NH C14 hsf installed. Didnt see anyone mentioning the H80. So at least you should be able to use a H50/60/70 hydro coolers or a very good HSF option.
Edit: The Noctua user posted on page 2 and the h70 user posted on page 4.
No, an H80 will not fit in the top fan slot since the motherboard is like 1 inch away from the top 140mm fan. I have an H70 and it is mounted where the front intake fan is but if you do this you cannot have a card longer than a 6950/70.
