electrichead
- Apr 25, 2005
Hi. First time poster, long time forum lurker(guest). I've see some great mods, and funny posts so I felt compeled resently to join in the fun and start posting.
About 2 years ago I bought my first PC, I picked up a 9000pro the next day end set off on a fantastic journey...yes I was introduced to the interactive crack we all have come to know as Counter Strike!
Last week my 9P(ATI9000pro) started make this buzzing hurrrrrrr like noise. My mother has a small dog that barks when the wind blows but not even little Georgie is as annoying as the noise that is comeing out of the 9P.
Conclusions.
1. Buy new GPU...I would, but I don't have much money it looks like conclusion 2., suits best.
2. Replace the fan.
3. Drown out the noise by playing Tom Wait's Rain Dogs on repeat 24/7.
So I opened up the panel to check out the GPU and found that the fan rests inside a heatsync coweling. With a tape measure I found that the cowling is 45mm wide, at least I hope. I would like to find a replacement fan, if anyone has any suggestions where/what to pick up that would be apreciated.
Heres a picture of what I'm looking at.
I've found a replacement fan, but I'm not sure if its what I'm looking for. It looks like the arms are the wrong way...I don't know if it'll fit correctly in the heatsync coweling.
http://www.adpmods.com/case-modding/Evercool-45mm-X-Type-VGA-Cooler-Replacement-Fan-p-1663.html
If anyone has any suggestions I would be thankful.
Thanks for reading
Conclusions.
2. Replace the fan.
Thanks for reading
