Format _C:
- Jun 12, 2001
I am volunteering at a local community center for the elderly & the disabled and they were recently given ten OLD PIV computers
Some of the computers are of the internet and others will not get access even though they are connected to the network (XP Says Limited or no access) as soon as I unplug one computer another one will be able to connect
The ISP is Charter Communications and the account is a business account the modem is an SMC Networks
SMCD3GN-RES and the router is a POS Netgear WiFi G (Which I am going to replace with my extra N router)
Their network is all screwy and I want to fix it for them
They Currently have the two devices I mentioned + a 8 Port unmanged GB switch where the five computers are located (To simplify the ethernet wiring as only one drop is needed)
I think with the business account they have a static IP address and I believe they have access to more then one External IP address (I am unsure but I will get the details if needed)
I am by any means no network expert but I though with a router you only need one External IP Address for all of the computers as that is the main purpose of a router?
Charter is an Evil company and the modem is extremely locked down (I can't even access the setup page 192.168.0.1 or 192.168.100.1 and they had to be called to get all 4 ports active on the SMC Modem)
My main question now is can the ISPs modem limit the amount the Internal IP addresses?
I want to really resolve this problem as cheaply as possible, So every device can access the internet properly
Here is my plan (Please tell me if I am doing something wrong)
1. Get a better N router and another GB switch (All 4 Ports on the Netgear are used and three of them on the SMC modem)
2. Plug the N router into the SMC Modem and then plug the drop from the 8 port switch into the N router and use the rest of the router ports + another switch for the remaining devices
3. ...
4. ??
3. ...
4. ??
