Internal 4TB drive for $150
Didn't see this mentioned, it's a 5900 RPM drive, so don't expect great performance out of this.
But you get what you paid for with stuff like this.
From my understanding, even though it's a 5900 RPM it actually performs near a 7200 RPM due to it having less platters. So this is a good deal.
^Correct. And uses less power and makes less noise while doing it.
Had very good luck with Seagate drives. RMAed more Western Digital drives but I've also owned more.
when they're racing to put larger capacities out on the market before their technologies mature, they always sac the rotation speed... but the higher density usually makes up for the drop, especially if you're not using it in a heavy load environment
while it means nothing to you, it means to ME that the brand is unreliable and should not be trusted for data storage... mechanical hard drives have been around long enough that the basics of manufacturing should be solid and the assembly and testing parameters are sound...
I still have 4 IBM DeskStar 75GXP's that work perfectly. In fact, in my experience they were flawless drives. Obviously if I ran them for many years with no failures, they were the best drives on the market.
Regarding manufacturing processes for mechanical hard drives, there's still a pretty healthy amount of premature failure across the industry.
Well, yes, consider the date of the initial post.
But I reckon it'll drop again within the month.
I just got mine a few minutes ago. As for sequential performance its hitting around 161 MB/s sequential writes to the outer tracks during badblocks testing. However with that said not like the extra performance will make much difference in my htpc. Also the warranty states August 21,2015 so a little over 2 years.
Heat and moving parts kills HDD. Heat is their number one enemies. Make sure your HDD is in a well ventilated area.
I always stick a fan to blow straight into the a hard drive, keeping it about 10 degrees C cooler. And it lasts for a long while. Don't move the PC/laptop until you shutdown the system completely.
All the drives fail due to newegg's horrible packing. If you let a hard drive bounce around during shipping, it's a DOA or bound to fail drive.
THIS!!!!!!!111111oneoneoneeee
I've had almost every drive that I bought from newegg fail on me for their shotty packing habits. I called customer support once about it then tested the waters again to buy another drive... one layer of bubble wrap and all the bubbles were popped on the side the drive was touching the side of the box (that drive failed about a year later).
I vowed never to buy any hard drives from them again after that point.
I've had almost every drive that I bought from newegg fail on me for their shotty packing habits. I called customer support once about it then tested the waters again to buy another drive... one layer of bubble wrap and all the bubbles were popped on the side the drive was touching the side of the box.
I have that problem with all my hard drives that get delivered. Delivery person always tosses them over the gate onto the concrete. I don't think they are made to withstand that kind of a drop.
As a person who worked in a point of sale parts department I can tell you the horrors that I've seen time and time again from stores not packing stuff up properly. I won't go into details here as that will get the thread too far off topic...
But what I will say is, as a person who was constantly sending parts out to stores I knew what it took for that package to get there in one piece. Newegg does the crap packing they do to save a few cents and hope for the best. If I were in charge of their shipping department I'd make darn sure the drive was packed properly with AT LEAST 2 layers of wrap.
Again as a person who actually shipped computer equipment out the basic rule of thumb is pack the package like it's going to be dropped from the top of your house. Worst case is that the package will be subjected to that kind of abuse.
Gotcha, I usually prefer to order from newegg since they are only like an hour from me, the package usually does not have to travel very far. But their new returns policies suck compared to amazons.
Speaking of amazon... their price for the drive in the OP is lower then newegg's current price :)
Not as cheap as the OP, but still not that far away price wise :cool:
my useless anecdotes. HDDs just suck now. I ran for decades without ever having problems with any hard drives. When they hit about 2TB suddenly reviews were just bad and I started to see real failures, maybe its because I tend to get them only on sale so I am getting lemons. Had a Seagate come free with a CPU and it was loud and eventually failed, had a WD come for $20 with a CPU at MC, still have it but the thing is clearly not stable the computers its been in all get random errors and need to have programs reinstalled here and there. Maybe the flooding in Thailand had something to do with it. maybe SSDs caused HDD makers to cut corners or maybe the density is just so high its easier for things to go wrong. But I believe the HDD makers know this or something because we have seen HDD warranties slip in recent years used to be 3 or 5 years now I find some with only 1 year now that's not an anecdote that's real info you guys can see. I feel like I can no longer trust HDDs at all since patters hit 500GB or so.
What kind of power supply are you using in the rig?
I found it a problem that whenever I used a low quality or bad power supply I'd have stuff fail for no good reason.
I own 5 rigs these HDDs have been in all different ones but were never in the same one.
Just so happens the WD is now paired with an X58 system and a 650 watt XFX PSU
Seagate was in a z68 with corsair HX620 or 850 and moved to a antec eco PSU I think 580, it was loud from day 1 but what can I do it was free lol.
After those 2 HDDS I had to buy a bigger 3TB drive for the HTPC and I did a lot of research not wanting a lemon. At the time it seemed there was more negative info about Seagate and ironically tons of sales tempting me to try a Seagate. During that time I saw what I considered to just be very high bad reviews from amazon, newegg, etc on HDDS and also noticed the reduced warranties.
I definitely know about bad PSUs though, holy shit I had a gateway computer given to me with a shitty PSU, I tried to run it as a spare HTPC and the thing was nothing but problems for years. Also had a rosewill case that came with a PSU what an utter piece of garbage. With bad PSUs they are so hard to diagnose.
Almost 68 hours later. The drive passed my 4 pass badblocks so I am now ready to risk using it on real data:
Code:
fileserver1 ~ # badblocks -wsv /dev/sdl
Checking for bad blocks in read-write mode
From block 0 to 3907018583
Testing with pattern 0xaa: done
Reading and comparing: done
Testing with pattern 0x55: done
Testing with pattern 0xff: done
Testing with pattern 0x00: done
Pass completed, 0 bad blocks found. (0/0/0 errors)
fileserver1 ~ # smartctl -A /dev/sdl
smartctl 6.0 2012-10-10 r3643 [x86_64-linux-3.7.7-gentoo-fileserver1-raid1] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   105   099   006    Pre-fail  Always       -       9580808
  3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       3
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always       -       27233
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       67
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       3
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   095   095   000    Old_age   Always       -       5
190 Airflow_Temperature_Cel 0x0022   075   073   045    Old_age   Always       -       25 (Min/Max 23/27)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       3
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       6
194 Temperature_Celsius     0x0022   025   040   000    Old_age   Always       -       25 (0 23 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       84907208474691
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       31256148672
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       31256149434
I am willing to bet you'd buy a GM...
My personal experience is 3 Seagate drives and 3 failures......
20 wd and NO failures...
i've had equal amounts of failures with both brands, but at different timeperiods... i at one time had a bunch of seagates fail, then i bought a bunch of WD, and they all started to fail...
i'd say after the years and years of IT work they're all around the same with failure rates...
what i've not had fail yet are any enterprise grade drives, but i buy so few of those that it's hard to say....
i had a few year old seagate 1.5 go out on me recently... only when warm after a few hours though, so very easy to get the data off, :shrugs: i'll buy another seagate, i don't care.... you should always have a backup, no hard drive is good enough to trust it with important data, i don't care who makes it...
