Altron3k said:look up some duplicolor. I think thats the car paint stuff
Qtip42 said:Dont confuse rattle can for real car paint. Rattle can is vastly inferior.
firewolf said:Spray some primer and then your color of choice, I'm donig this soon since I have a window and everything inside is metal for some cheap reason.![]()
Indeed. "Rattle cans" made for automotive applications are generally better qualityStuey83 said:True, but duplicolor auto paint in a rattle can is generally better than your average rattle can paint.
But for the interior of a case, I don't think the type of paint will make too much of a difference.
Hammertones are some of my favorite finishes...how can you not love a finish that's designed to f*ck up?Zamboni said:Hammerite spray works well for the inside. The orange peel effect extends into every noo and cranny and curve without any surface prep beforehand (or sanding afterwards).
How nice, colored boogers. Ever have silver ones?alik4041 said:I dont wear a mask or anything so my bogers turn into the color that I'm spraying![]()
