BellaCroix
- Mar 25, 2004
Sorry for the noob question:
Just wondering... all the parts of the watercooling set-up I'm planning have started to arrive and I'm laying everything out to decide where everything should go. Had a question as I was visualizing everything together:
The case is a Lian-Li PC-7x and I was considering putting a Danger Den/Laing pump in the HDD cage but then I started wondering... I imagine the motor on the pump is not shielded (I see no UL or FCC interferance notice) and I was concerned about what kind of problems that might create if mounted so close to the HDD which will also occupy that space.
Yeah, yeah, I know, there's motors in the HDDs that don't create any kind of problem and many people have fans mounted in close proximity to HDDs but I just wanted to be sure I wasn't missing anything.
Has anyone ever heard of any problems with pump motor interferance?
Also, as a side note... looking at the rear of the pump there appears to be a small header or jumper, like the headers on the motherboard for the Power/HDD activity LEDs, what is that for? Is that actually a LED header to alert for pump failure? I was going to jab an LED onto it but didn't want to go shorting out a $70 pump out of curiosity.
Thanks much,
BellaCroix
Thanks much,
BellaCroix
