i recently switched back to using my msie 3.0 and now every time i restart, my mouse settings are apparently switched back to the default settings, what gives?
Which OS? If Vista make sure you run the driver install as admin I've had problems with drivers etc not fully installing even though they act like they do under Vista if I don't do this.
I just unplugged my logitech 2-button mouse and replaced it with a new IME 3.0 this morning. I literally unplugged the USB and plugged in the IME and it works fine.
I am guessing it might have something to do with any drivers you had installed from the previous mouse.
assuming it is a problem with the drivers from my previous mouse, how do i go about in fixing it? is there some sort of driver cleaner for logitech stuff?
