IntelBurnTest v2.0
Buttnose
Code:
 IntelBurnTest v2.0 Released
IntelBurnTest is a CPU stress benchmark for testing stability of your x86/x64 processor. The new benchmark is said to be extremely processor intensive, so much in fact that it can load your CPU 22'C more than the well known Prime95 benchmark? Keep in mind to use this program at your own risk.
DOWNLOAD: IntelBurnTest v2.0
Requirements:
- An x86/x64 CPU
- At least 512 MB of system memory. Recommended minimum is 1 GB.
- A modern Windows-NT based operating system (XP and above). Both x86 and x64 are supported.
- Microsoft Visual C++ 2008 Runtime (x86), can be found here.
- Microsoft .NET Framework v2.0 (minimum), can be found here.
Changelog:
IntelBurnTest updated to v2.0!
- Completely re-coded from the ground up
- New, intuitive graphical user interface
- Windows Vista/7 Aero friendly
- Real-time result output
- Real-time error checking, auto-stops when error occurs
- Simplified stress level selection
- Easy copy of results to clipboard (right-click context menu)
- Built-in system freeze test (animated flame)
- Real-time free system memory display
- Uncluttered integrated title/status bar
- Added log results to file feature, with date and time, CPU/RAM info
- Displays total time taken to complete test at the end
- Correctly detects the maximum memory limit for x86 Windows
- Fixed a bug that caused testing memory to be limited to 6.1 GB
- New eye-catching icon
- Various bug fixes carried over from v1.93
http://www.techpowerup.com/94600/IntelBurnTest_v2.0_Released.html
