Intel Shelton, odd mobo help
Qwertyman
A while back i got an intel shelton mini-itx board similiar to a via epia which worked on arrival. I was fooling around with it using a screwdriver to start up the pc by using the old touch two jumpers trick. Anyway it worked after that, but now I can't seem to get it to work at all and I think I might have fried something because of my stupidity.
If i power up the mobo, the led power on light stays constant the whole time and the reset and power buttons work. I cannot get to a post screen at all even after resetting the bios.
I also get a flash of light on my keyboard for the num lock button and then it dies out, usually i have access to switch this on and off.
The video output does not work at all and neither does the usb mouse.
I've tried different ram and no luck.
Is it definately a fried mobo or should I try to reset the bios another way or even flash it?
Any help would be appreciated. thanks
it might be a far shot, but try a new PSU and/or a new CPU.
Does it beep at all?
If you have access to a spare mobo for your processor, give that a shot too.
was your hand touching the metal on the screw driver? I've popped a mobo that way. Strange.
