Innovatek question...
Parabellum
Hi,
I am thinking going WC and so far, I have some interests in the innovatek WC components. What do you think about it?
What I like about these is the pump that can be plugged directly on the PSU, those fancy fittings, good design and looking. How is the performance? Say, the XX flow wb or their newly released innovacool rev. 4. I think however going with a thermochill 120.1 rad instead of innovatek one and probably use some 3/8 tubing (tygon) instead of 8mm (they have adapters available for this)
I am quite sure it may not be the best performer how would it compare to my actual air cooling setup? I have a thermalright SP-94 with a Panaflo M1A 92mm blowing about 47CFM. I can hit 3.9GHz but is not enough stable at that speed.
Thanks for any input,
Para
The Innovatek stuff is on par with any 3/8 system out there, with more than enough power for your needs.
Thanks dude for your input! Anyone has a comparison between Innovatek stuff and my SP-94?
Para
