Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I think that its probably either a bios update u need or...
You probably need SP2. There isn't really a tool for it, it just allows bigger hard drive addressing.
well you'd need to user partition magic to resize the partition to use the entire drive, OR, if it's not your system drive kill the main partition on it and assign it new, OR, goto disk management and format the rest of the drive as another parition and assign it it's own drive letter.
