Increase Frame Rate and Alpha Coverage
Eastcoasthandle
EATM & ATMAlphaSharpenmode to your ATI video card (ATMAlphaSharpenScale & ATMAlphaSharpenBias can be added as a bonus)
Enable EATM is like Adaptive Anti-Aliasing but has reduced performance hit vs. Adaptive Anti-Aliasing. EATM increases alpha
Coverage/Detail and it's noticeable in games like Wow, Oblivion, etc (games that use vegetation, etc).
Enable ATMAlphaSharpenMode suppose to fix artifacts and helps image quality, while still being very fast
Here is an example:
Adaptive Anti-Aliasing (EATM OFF)
http://i11.photobucket.com/albums/a154/eastcoasthandle/EATM/performanceye8.jpg
http://i11.photobucket.com/albums/a154/eastcoasthandle/EATM/RACE_EATM_OFF.jpg
EATM
http://i11.photobucket.com/albums/a154/eastcoasthandle/EATM/eatmso1.jpg
http://i11.photobucket.com/albums/a154/eastcoasthandle/EATM/RACE_EATM_ON.jpg
You cannot see the difference until you open this pics up in their own FF or IE tab or window and switch views.
In order to obtain this level of quality with increase frame rate here is what you need to do:
You need Cat 6.12 (this only works for ATI Video Cards)
Download ATI Tool Tray 1.2.6.964: http://www.guru3d.com/article/atitraytools/189/
Enable EATM by Going into Tweaks, then Advanced Tweaks, then in the drop down menu select New AA and AF methods. EATM should be the 4th
one down. Then check EATM. Activate EATM through ATI Tray Tools.
Search for EATM in your registry. Once found Add ATMAlphaSharpenMode as new string. Then add the value of 1
You can also add ATMAlphaSharpenBias & ATMAlphaSharpenScale as a string if you like. Then add the value of 1 for each.
Disable Adaptive Anti-Aliasing in CCC. You can keep it enabled but you will notice a big hit in Frame Rate.
Enable AA either in game or through CCC
Reboot then play your game.
Or
If you want to use ATI Tool Tray instead of messing with the registry do this (please note that some have reported crashes using ATI
Tool Tray instead of the Registry):
Make sure you have Cat 6.12 installed.
Install the latest version of ATT 1.2.6.964: http://www.guru3d.com/article/atitraytools/189/
Install ATI Tool Tray.
Go to X:\Program Files\Ray Adams\ATI Tray Tools\Database and open New AA & AF Method.dtb with wordpad.
Add the following commands after "Value12=ZMRA,ZMRA,0,0,0,"
Value13=ATMAlphaFix,ATMAlphaFix,0,0,0,
Value14=ATMAlphaSharpenBias,ATMAlphaSharpenBias,0,0,0,
Value15=ATMAlphaSharpenmode,ATMAlphaSharpenmode,0,0,0,
Value16=ATMAlphaSharpenScale,ATMAlphaSharpenScale,0,0,0,
However, this method doesn't use strings in your registry. Which can explain why people are having problems.
Enabled EATM and the ATMA's
Reboot and start your game with ATT enabled. (make sure these tweakes are enabled).
In BF2 clear your cache (BF2 should tell you that it's optimizing shaders if your don't.)
Side Effects:
transparent Alpha blends found in this
example:
Side effects are the result of games not really using this type of method IMO. However, the benefits in increased frame rate with
better
overall view outweighs this. Another side effect is using Media Player Classic and WMP11 you may or may not experience OS crashing /
freezing with switch to blank screen. No one knows what ATI Cards this will not work with. So far I've seen people post from x800 to
x1950, this is all I know so far.
Side Note:
EATM and ATMAlphaSharpenMode have values greater then 1. However, because the games are not designed to take advantage of this feature
(& because ATI has not officially supported this feature yet) you may get less then desirable results.
http://www.rage3d.com/board/showthread.php?t=33876334 <---link
http://www.driverheaven.net/showthread.php?t=125073 <-----Link
