Incorrect storage capacity?? please help
Krenum
Hello, ok I have one for you guys, I recently formated my hard drive on my computer, earasing the partition then creating a new one and formating , but recently my hard drive has been showing the wrong amount of storage space it has. I only have one game and a couple of programs installed. Its a 80gb hdd, showing 17gb free. I dont know whats wrong, could it be that my Hdd is going out?
Im using Windows xp 32bit if this helps anyone diagnose.
Well you say you just recently reformatted, sounds like you may have made a smaller partition than you intended, check out Disk Management and see what it says
I am certain that i made the partition for 74gbs, this just happened the day before yesterday. I found that my C:\Documents and Settings folder says that it has 46.8 GB's of data in it :eek:, I have no clue were all that information is , Ive looked through every folder in that directory and have not found anything that reads 46gb's of data.
im stumped.
Ok i found it, I had windows show the hidden files and found that a temp folder was holding 46gbs of data. Anyways problem solved , thanks for replying .
