Immediate Help Needed!!
gullyrip
I just finished building this dual monitor setup and I have a problem w/one of the monitors blinking suddenly. Has anyone heard of this problem? I have:
3500+
neo2 plat
1gb gskill le
74gb raptor
evga 6800 ultra
and 2 x 2001fp's
It only happens on the main monitor. So i'm thinking its the card.
ok it seems like it only happens when i'm updating HL2.
try swapping connections on the displays and see if you still have the same issue...if it follows the display it probably isn't the card...but a more detailed description of the issue would also help
what kinda connnectors u using? dvi or d-sub? and if ur using monitor extention cables make sure they are high density cables instead of the shitty ones that u can buy at walmart :) but you may be having power issues. try the blinky monitor by itself, if its the monitor then send the bitch back to dell and have them send u a new 1, kuz most likly the psu on the monitor is faulty and could be arching (possibly could cause fire)
I switched the dvi cables in the back of the card and it seemed to stop momentarily. weird.
