Last upgrade was at xmas, been fine since then... then the other day I try to flash my mobo's bios. It starts flashing and I look away from the screen for 1/2 second and look back and the computer is at the post screen booting. First I was like 'wow that was fast" and then i thought "wtf it didn't say "Done, now u can reboot" or anything". But I quickly catch the it and hit del to put my settings back to how I had them. ... blah blah ... alot of stuff happens... bios is messed up somehow. Most likely, it just messed up while flashing and it was a bad flash. I rmaed it cause I didn't do anything wrong, I dunno why it failed flashing.
Since I'm computerless might as well also order a mobile2600+ and nf7=s right? So that gets here yesterday. Put it all together and turn on, my plan being to burn stuff to dvdr and format windows to start clean. Windows starts all is good and it starts automatically installing drivers, ugh and then tells me to reboot. So I say fine and reboot, windows gets to login screen and says "unable to write to c:\win" and that message pops up 50 times trying to write different things and then windows kinda hangs. Uh.... fast forward 10 minutse of trying stuff I get in safemode and burn my dvdrs.
I boot to dos fdisk kill my c: and then create a new partition there
I boot to wincd .. it loads drivers and then.. blue screens YAY "UNMOUNTABLE_BOOT_VOLUME". Wow wtf is that huh.
HD borked? Cept I was able to safe mode fine. UDMA messed? I turn it off in bios, no difference. Try new ide cable no diff. I try using a sata converter and not even using ide controller, no diff.
Huh... harddrive just broke somehow?
Use WD test utility thing off a floppy, extended test.. HD = good.
Huh file system somehow broke? some other test program = pass.
memory maybe bad? memtest86 = good.
i can do anything in dos with no problems
I unplug the harddrive and just try to get windows boot cd not to crash... no go, blue screens every time.
I'm down to mobo+cpu+ram+videocard+dvdr
Not sure what could be broke if I can do anything in dos with no problem.
Look up the unmountable_boot_volume, microsoft says I should make sure i'm using 80pin cable (not 40) or make bios use lower udma mode... THX ... first it is a 80 pin cable, tried 2 for the hell of it, and then i tried sata- no go, bios i turned udma off and used pio = no help... then i just unplugged the hd itself and still get errors.
so what should i try... heh.
BTW
between old computer and new stuff, only common ones are
ram video dvdr
ram: memtest86 can't find an error after like 5 hours
video: why would this kill winbooting? plus i was in windows a few times first time i started new one, safe mode. tho maybe i'll try something else for fun
dvdr: tried unhooking initially and having only hd and windows login still freaked so i deleted windows... so still messed without it
Could video card do all this? Whats it have to do with writing to the harddrive?
/me looks for some old videocard in closet
BTW
ram video dvdr
