I'd say rather than looking at caps vs no caps to judge whether it was malicious, I'd look at where it was/running from. I have seen both the upppercase and lowercase spellings for internet explorer.
In task manager->view->select columns, add "image path name" and see if it points to the same file.
He was referring to Vista's task manager. Right click, select properties and the location field will be the same thing.
I may sound pretty stupid asking this, but I actually wanted to try that at my work PC... and I can't find that checkbox! I'm running Win XP sp3 32-bit...
Here, take a look:
I have "Image Name" greyed out, but -of course- the only thing that reads in that column isn't the file path, just "iexplore.exe". Are you referring to the Vista taskman version, or XP's?![]()
