IDLE temp VS Load temp
legcramp
Hi guys, Specs are in my sig, and I run my FX-55 @ 1.52vcore
Idle temp currently with an Arctic Cooler Freezer 64 Pro is 29c ( I did the sandwich mod for it )
Load temp with Prime95 for a couple hours is 47c
My question is, why is the idle and load temp have such a BIG gap?
I have seen people get similar idle temps as me, but thier load is under 10c difference :(
Depending on the CPU, ambient temps, case cooling, overclock, voltage, etc. the gap between idle and load can fluctuate a lot. Honestly, it really isn't worth paying attention to the idle temps since the stability of a system depends on the highest temperature the CPU will reach(among other things).
not to mention that the FX series chips are AMD's hotest running chips. I've owned several of them, as they are great chips, but damn hot.
