Ok, I installed a new P45-UD3R over a 939 board without doing a fresh install - big mistake.
I got it so everything is working - I can surf etc - but I have DVD drive problems:
1. If I autoplay a disc, it takes a long time, like 3 minutes, but eventually shows the disc menu. I can then install something, say Crysis - but try to run it and the spinning drive mouse symbol sits there forever - I can continue browsing existing windows, but can't do anything else, til I do a hard reboot.
2. I can't seem to reinstall windows cause (a) the board won't read any floppy drives, and (b) if I run XP CD, it BSOD while loading drivers, saying:
pci.sys - Address F748E0BF base at etc
Symptom seems familiar, anyone know what it means? I removed all the old AMD drivers, removed the IDE drivers and reinstalled them etc.
Edit: Found out the pci.sys error is a compatibility problem with new chipset and XP SP1. DVD problem was solved by attaching the drive externally through USB. I'll just get an SATA drive.
