I have an A7V8X with SATA, before the problem started, I had a WD 120gb PATA drive with a CD burner. I then installed a Seagate 160gb SATA drive with a DVD burner (Liteon 812s). Everything worked just fine. But after rebooting the computer ~5 times, every IDE drives disappeared (2 optical drives and 1 hard drive).
The problem is, they're detected with no problems in the BIOS, but when I get in Windows XP, I only see the 2 partitions of the SATA drive. (Windows is installed on the SATA drive but the boot sector (is that the name?) is on the PATA drive.)
At first I thought it was a powersupply problem (Antec TruPower 430w), so I unplugged the 2 optical drives, but it didn't change anything. I tried changer the jumpers on every drive, changed the IDE channel, tested one at a time; nothing worked.
Does anyone know what could be the problem?
