Peltier Device Information Directory:
(Scrole down after clicking)
NB!: You will have to calculate the heat your CPU dissipates, taking speed and voltage into account, and get a pelt that can dissipate that amount of heat and more.
Try the CPU Power Download
(No its not a Virus; just hidden on the page I found the link on)
DONT power up a pelt that has no cooler on its hot side for more than a second.
Also; on one of the manufacturer's sites you will find info on the importance of clamping pressure for a pelt.
Linkage
So you gotta have a cold plate and screw it to the hot side with LOTS of pressure!
Any other info and links youall would like to add are welcome.
Linkage
