I have a really old IBM Powerserver 320H system that is needed for access to some old data.
The system will only power on fully every once in a while and since parts are not available for it, I was wondering if software that was made to run on an old version of AIX should run on a newer version of AIX provided the newer system is also has an RS/6000 type processor.
Well.. according to IBM.. it should work. I am not sure of the version of AIX on the old system though. I am thinking it is probably 4.3.. but it may be some 3.x version. If I can ever get it to power up fully again I will check.
http://www-03.ibm.com/systems/power/software/aix/compatibility/guarantee/index.html
