Hi,
It's been a while since I've home built so I've been trying to catch up. Wondering if
I could get some feedback on the list to make sure it'll all work together.
I'm not really looking to OC but might try it a little (not extreme) later on, long
term stability is more important.
MB: ASUS P6T
CPU: Core i7 920
Video: GeForce GTX 260 (probably not), 280 or 285, depending on deals, SLI later on
Case: Antec P182
PSU: Corsair TX750W or TX650W
RAM: Kingston 3x1 DDR3 1333
WinXP (already have) (later: Linux with virtualized Windows)
Display: Dell 23" 2048x1152 (already have)
All stock fans
Kybd, mouse, hard drives, optical drives, speakers: already have
Will the PSU fit in the case while keeping the bottom fan?
Will the PSU cables reach (PSU is at the bottom of case)
1) What will you be doing with this PC? Gaming, video editing, web browsing, DVR, virtual machines
2) What's your budget? Are tax and shipping included? NA
3) Where do you live? NY
4) What exact parts do you need for that budget? See above
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. See above
6) Will you be overclocking? Possibly a little later on (air, not extreme)
7) What size monitor do you have and/or plan to have? As above
8) When do you plan on building/buying the PC? very soon
9) What features do you need in a motherboard? RAID, Firewire, SLI
10) Do you already have a legit and reusable/transferable OS key/license? yes
Thanks!
MB: ASUS P6T
CPU: Core i7 920
Case: Antec P182
All stock fans
Thanks!
