i7 950 OC help.
jam3s121
My system
i7 950
gigabyte ud3r
6gibs of corsair xms3 (triple channel config)
msi gtx 560 ti
samsung f3 500gb
corsair tx750watt psu
I am trying to stress test my current overclock with IBT or LinX
Both tests are giving me errors saying my cpu is not stable, it does not BSOD or crash my system though instead giving me an error.
hyperthreading and turbo mode OFF
bios settings
multi set to 21
bclk set to 180
dram freq spd is set to 6
vcore is set to 1.28
qpi/vtt set to x36
dram vcore 1.64
cpu pll 1.84 (someone told me to raise it a notch
You might wanna try upping your QPI Link voltage a tad since its overclock just a hair. Looks as if HT Link and QPI are almost the samething just difference platforms.
More vcore? I run at 1.35v and can do 21x200 (4.2ghz) without a problem on an H70. What is your qpi voltage? I hear ~1.35v is a good value for this, and it's what I run.
