i7 920 Overclocking Help
Zetro
Hey Guys, I am starting to get the feel for this whole LGA1366 overclocking but I seem to have run into a wall and some insight would be great.
The Rig:
i7 920 @ 3.6GHz (180x20 with 1.2V)
Asus P6T SE
TRUE with Push/Pull
Corsair TX750
Here are the settings that don't work:
BCLK Freq @ 190
PCI E @ 100
CPU V @ 1.25
CPU PLL @ Auto
DRM\QPI V @ 1.25
IOH V @ 1.2V
IOH PCI V @ 1.5V
Dram Bus V @ 1.6
Ram timings are at the stock CAS9
Heat is not an issue, I get into Windows and the machine just BSOD's.
What do you guys suggest changing up to get some more stability?
1.) What memory did you get?
2.) What speed did you set your memory ?
From the info you have currently given, I would suggest you increase v-core...
try 1.25....then 1.275, them 1.30.
