Hello all,
Before I bought my i7 920 I read that the default voltage is 1.2, however, I checked CPUZ and my default voltage (at Auto) is at 1.056. Do I need to set it at 1.2 manually or should I just leave it alone?
I am not oc'ing yet and I have the Speedstep and other stuff "Enabled". My processor is running at 2.8ghz.
Should it be defaulting to 1.2 or since it is set to "Auto" are my readings normal?
Thanks!
*EDIT* I suppose this is normal since when I run Orthos it shows 1.25 in CPUZ. Am I correct in this assumption?
Thanks!
