Just finished an i7 build and I'm a little curious about temperature differences across the cores.
i7 920 @ stock / Vigor Monsoon III / Arctic Silver 5
Asus P6T (Bios settings Auto)
OCZ 1600 3x 2GB @ stock
Asus HD 4830 512MB @ stock
Antec P182 Case
Corsair CMPSU-850TX Power
When first turning on the machine, temperatures are as follows:
After about an hour of Intel Burn Test:
From what I understand, the Antec P182 isn't a monster in terms of cooling. In addition, the 4830 seems to be running around 50C and doesn't exhaust from the back of the case.
Given this setup do the temperatures seem right?
Also, for temperatures:
Cores 1 & 2 seem to run pretty close to each other. Core 0 runs a few degrees hotter, while core 3 runs several degrees cooler than everything else.
Does this look normal or seem a bit off?
I used the credit card / thin spread method for the Arctic Silver rather than dot in the middle or line.
Given everything above, what are your opinions on whether I should clean and reseat the cooler using another method?
Antec P182 Case
