I am just wondering if it is normal for my CPU's core temps to be constantly fluctuating. I have a ASUS P8Z77-V LK motherboard and a Hyper 212 plus in a Corsair 200R. I've been using HWMonitor to measure the temps.
The temps basically never stop changing from second to second, they are fluctuating around +/- 2-4 degrees C all the time. I'm just not sure if this is normal or not, I also have a core temp difference of 8-10 degrees C between cores 0/3 and core 2 (hottest core). I just want to play it safe and be sure this should be happening.
Also does anyone know which setting turns off the automatic CPU clock/voltage adjuster in the ASUS UEFI bios, I feel like it could have a negative affect/lead to unstability from constantly lowering and raising the clock speeds/voltages.
