extragoode
- Jul 22, 2004
I built myself a computer a couple of years ago. It's an Athlon XP 1600+, 2x512 DDR2100, asus A7V266E mobo. Initially I had an asus 32MB GeForce2 MX 400 Dual Head and a 425 watt PS. I recently had the opportunity to upgrade and the GeForce2 wouldn't let me run my two 19" at their 1600x1200 max desktop space. So, I grabbed a gainward 256MB GeForceFX 5700 for cheap.
That worked great for a month or so, then I started getting this screen with a bunch of diagonal lines in multiple colors that popped up when I switched into 3D mode. Then it started happening right after windows started. Gainward said it was a driver issue, that I could only use their drivers, and not the nvidia ones. So I got theirs and no difference.
I started taking apart the computer and found a dark spot on the ATX connector, so I thought the PS bit it. It was only $25 2 years ago, so sure why not. I had an extra 350w lying around so I put it in. Still the same problem even with the 2 HDDs and 2 CD-ROMs unplugged (cause I wasn't sure if the 350w was enough for that FX5700.
Now it runs semi-stable when I underclock it about 30%, but still locks solid in 3D mode. I've underclocked the vid card so the 3D settings are the same as the 2D ones, and I've tried powering everything I can off of another 200w PS I've got and just let the 350w power the mobo, just to see if that helped anything and it didn't.
Any ideas?
Any ideas?
