Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
For the last time... I AM NOT A RETARD OK.. i am not plugging the keyboard into the mouse slot, the mouse slot is green along with the mouse plug.. ok i checked also.. so stop calling me a retard in code.
a) Clearly state the problem.
b) List full specs
c) List things that you have already tried
d) They are calling you a retard in code? I need the latest issue of "1337 5p34k f0r Dumm135"
Those should help you get more responses.
Also, glad to see that your spelling has improved since that last thread.
have you tried another keyboard? how did you get into your bios with a dead keyboard to even see that the "ps2 power on" option is disabled...
use the process of elimination.. find a keybaord that does work for sure.. and see if it works on that computer.. if so.. the keyboard is dead, if not something else is wrong..
You are a lil late guys.. I fixed it.. Posted in another post sorry lol.. I fixed it.. anyways.. for BIOS do i have to edit them.. or just save the defaults and then just friggan go on?
well, that was interesting.
i figure by now, most motherboard companies would have support for keyboards.................
Last time i checked, the ps2's are on in your bios unless you turn them off. which is
probably not the best idea.
