I need some help
AMDXP
I have seen this before well an yway here it goes I have a p4 3.2 ghz, 5700 ultra 128 mb/128bit, 3500 1 gb of ram, Decent cooling 6 fans counting heatsink.... Heatsink operating at 4500 rpms
Well the main questions is sometimes when I play ut2004 my computer shuts down by itself and reboots my comp is brand new too. I am wondering if the 5700 ultra is bottle necking the system and causing it to shutdown.
Its mainly ut2004, I can run cs fine and that except for ut2004 and ravenshield.... I have had no other problems with my old machines and there ati cards, this is my first nivida and if Is the case makes me wonder if I should get the x800 pro instead of the 6800gt
Oh I dont have anyother agp cards I can test.
I'd say the 5700 is *probably* overheating, its not really a great card anyway...
I would still definatly get the GT over an X800Pro, in most cases, the GT is closer to XTPE performance than the Pro.
Yould wouldnt happen to be on pbnation would you?
I dont know Ive had great luck with ati cards and never had a problem......
*EDIT PowerSupply is 560 watts.
Brand and rail values? My guess is a cheap PS, from what I've seen so far.
Its a thermaltake and I dont think it has anything to do with psu....
I put my money on the vid card.
have you opened the case and run a game in order to see if is overheating
is the gpu fan working?
Yeah everything is new, its dual channel 512 mb s each and the fans working. :rolleyes:
In that case, no, it's probably not the PSU. These problems can often be the PSU though.
Does the 5700 have a thermal diode? Temps?
If it was the psu I believe it would restart very often like on my old comp which had a bad psu and would be a pain to start I bet its the video card.... still....
