I need help with a decision
Mijae
Right now I have a p4 2.4c cooled with a Zalman 7000al-cu, and its running very nicely at 26°C with room temperature of around 19-20°C. I guess those are pretty nices temps, but I was considering getting a watercooling kit (swiftech h20-220-p).
But I am not sure. Is the $190 kit worth a few less °C? I guess it would become noticeable when running at full...I just can't make up my mind.
Err... you overclocking? if not then theres no point. If you are, like ALOT then water cooling. Explain more about your situation.
sounds like you have a very cold room, you dont need h20 cooling if you aren't gonna overclock, your temps already sound awesome
Well, I have the money...and a water setup would look pretty sweet. But I guess I would be better off buying a new monitor.
I just cant decide.
make it easy for yourself and buy something that you will actually have a use for.. in your case, watercooling would just be throwing money away
