I need a big case
Oj101
I'm in the market for a big case. It must be big enough for:
3x HD2900XT, water cooled, with the possibility of a fourth
Suction arm for Prometeia on the CPU
4x Hard Drives
2x DVD writers
Non modular PSU
Enough free space inside for neat cabling
I currently have an Antec SX835II which is WAY to small. I need something HUGE. Recommendations?
I've looked at the Antec 1200 but it isn't deep enough.
I've also looked at the HAF 932 but the styling doesn't appeal to me at all, I want simplicity. I don't like all the mesh grills, the embossed design on the right or the plastic part at the top. If the P180 was bigger I'd grab one.
Oh, and it must be black.
If you like the HAF look at the CM 840. Also look at the Silverstone TJ07 (though I don't usually recommend this due to quality issues for the price).
There are also a couple of good LL models (don't remember which right off), but I'm sure someone will pop up with them soon enough :)
IMHO, the HAF is hideous and the 840 isn't much better. I'll have a look at the Silverstone but I think the Lian Li PC70/71 is going to be perfect. It's a very deep case with space above the PSU for the radiator, pump, etc :D
My Edit button isn't working, the Silverstone is PERFECT, BUT... The section at the bottom means the evaporator head won't reach the CPU.
LianLi Armorsuit P-80. Absolutely huge, good airflow. TYR-2000 series could work too, but it is a little more broken up compared to the Armorsuit. It is the best case I've owned thus far.
Check out what people can do with a little modding on million-dollar-pc.com. There's a white modded P-80 with tons of gear inside it.
Nice case but too "busy". I want a simple look, something like the PC-70/71 :)
Once again, the section at the bottom mean the evaporator won't reach the CPU.
You want a mountain mods case. The make towers now too, not just cubes, check out the pinnacle's and the monticle's
So, you mean big. Take a look at Mountain Mod's (way over priced, but every review I've seen just -glows-) for some more options in that size range.
TJ10 all the way. I love mine, and it is huge. it's the TJ09 with stealth drives. It's also really cool.
edit:shit.. didn't see the original date
Yeah this is an old thread. Otherwise you'd have seen more Corsair 800D recommendations. I'd also have suggested the Lian-Li Armorsuit. There is also the Mountain Mods U2-F0, Ascension, etc. Those are all very large cases.
