I'm about to give up on PC's (Building them anyway) I dont know what to do. Any input would be greatly appreciated.
This is my problem.
My 3.3, 5 and 12V are all at about 50% every time I boot I get a voltage error and my CPU temp has been going through the roof.
My Specs:
P5N32-E SLI Plus
Core 2 Duo E6600 2.4 (Stock)
OCZ 700W PSU (Upgraded today from Sparkle Power 550W)
2GB PC6400
400 SATA2 HDD
200 SATA HDD
7300 GS (I changed this with a 8800 GTS 640)
Still getting the 50% volatges even after the PSU upgrade, VPU Downgrade and a swap of the power outlett.
I honestly dont know what the issue could be aside from a faulty sensor on the MOBO but my CPU continues to heat up over 60 degree's C.
I'm at my witts end please offer any help or advice you can. I would very much appreciate any input. Thanks.
This is my problem.
My Specs:
P5N32-E SLI Plus
2GB PC6400
400 SATA2 HDD
200 SATA HDD
