I did something stupid...PLEASE HELP!
gutman
Ok so sometimes I can be really stupid and this happens to be one of those times. Well what happened was that I was trying to do some overclocking but my bios didn't have a agp/pci lock feature, so I look in my mobo's manual and it says that it's supposed to have it. Well i went online and did some research, turns out that that if you flash the bios to one of the new ones the feature is removed. So logically I started to flash the bios to older ones to see if it would come up. Well stupid me I didn't check to see what new cpu support the new bioses added to my motherboard and I ended up flashing it to one that doesn't support my cpu. Now my computer won't boot, it turns on, everything seems to be getting power, but it won't post, nothing comes up. My mobo is a ASUS A8V Deluxe Rev. 1.02. I need help is there anything I can do to fix it? Any help would be appreciated.
David
DR_K13 said:
:( I think it might be toast
just from flashing the bios to one that doesnt support the CPU? how is it toast?
i mean, there are a couple of options...
1. hotflash.
2. RMA
3. get a CPU that is supported, sell or return when finished
I'd look for a local computer store that might help you. A small, locally-owned store might have CPUs sitting around that they can just pop in to get it running and then restore the BIOS.
Agreed. Or if you have a friend that would loan you a supported CPU...
Wouldn't it be possible to just remove the CPU and boot?
The BIOS doesn't need a CPU per se, possibly it would boot up with an error saying "no CPU found" or some such.
Edit: Eh, though that still leaves you with the problem of restoring your old bios...
ummm the cpu houses the memory vontroller nad everything, board wont do anything without the CPU... lol
it wont boot.
I'm with them. See if you can borrow or rent a supported processor long enough to flash back a newer BIOS.
lmao that sux! i suggest you find out from one of your friends if they have an older chip im guessing an xp should be fine or just purchase a chip and return it. sux ass but thats the best you can do to avoid an rma
....an XP in a s939 board...?
right...
The a8v has two things you can try, it will automatically update the bios if it thinks its corrupt, by searching for a bios on the cdrom and floppy drive. Also the bios update utility is integrated into the system so you dont have to find a old dos bootup floppy, so you can stick a floppy in there with just the bios and press Alt+F2.
Its a longshot but I would stick a bios floppy in there and bash Alt-F2 alot, maybe you'll get lucky. Otherwise your going to need to borrow somes ones cmos chip or newcastle processor.
Thanks for the replies everyone, i really appreciate it. Just one question, what exactly is hot flashing? Never heard of that so if anyone can enlighten me that would great. I'll definitely try the alt+f2 thing, i've done it so many times i don't why i didn't think of trying it just to see if by some chance it works. Hopefully one of these methods works, cause if not then i guess i'm just screwed, cause i don't really know if any of my friends have an older cpu. Thanks again to everybody trying to help.
David
hotflash is this:
take the BIOS chip out of your non-working board.
boot up another computer with a socketed BIOS chip, and boot to an A: prompt
take out the BIOS chip of the running computer
put the chip of the non-working board in
force flash the BIOS chip with the bios you want
take the newly flashed BIOS out, and replace it with the BIOS of the board that is running.you can shut down that PC now.
put the flashed chip back in the non-working board, and boot up.
If it comes down to it, you could always purchase a new bios chip flashed to the latest bios from like biosman or something.
Can I pop the bios into any board, or does it have to be an ASUS board? The only reason I'm asking is because I already bought another board just to get me by for now but it's an ABIT. I can still return it so would it be better to return it and get an ASUS board and then try the hotflash, or would it work with the board I already have? Thanks for all the info guys.
David
any board with a socketed bios chip. you will have to Forceflash it, becuase otherwise bios protection will kick in and wont let you flash the chip with a bios that was not intetended for it.
When you say forceflash do you mean any dos based flash utility like afudos, or a specific flash utility or method?
David
dos based util, youll just need to look up switches to use with the exutable so that it flashes no matter what "incompatabilities" it finds.
