EDIT (5-15-07):
Turns out the FDD power cable wasn't secured correctly, and that caused the instability. Everything worked fine after I corrected that.
end EDIT
Fuck! I finally finished building my first PC and went to install the OS (WinXP Pro SP2).
Stuck in the disc when prompted to insert boot device or whatever upon startup. It began loading files just as usual and preparing itself for installation. I quickly went to the bathroom and when I came back I saw that a stop error had occurred. Okay, so I restarted and tried again.
Everything goes fine this time and it proceeds to format the HDD. Oh, yeah, my system specs:
Two WD 500GB sata drives
DFI NF4 Lanparty SLI Expert or whatever the whole fucking name is
AMD FX-57
P-180b/182
rest not important
So after two hours the format is finished. Only one of the two drives was formatted, and it was NTFS or whatever the proper acronym is.
On to WinXP set-up. Shit! It froze! I waited ten minutes to make sure it wasn't just stalling or some crap. Nope, it froze.
I restart. This time the screen just stays blank. No boot-up messages, nothing.
I figure I should check the cables inside to make sure everything is connected. The two hard drives are fucking warm! Must have been poor airflow that caused the stop error, freezing, and now blank screen. I clean up the cable management, move the two drives from the P182's lower HDD cage to the upper one and place the case fan that was in front of the power supply (Silverstone ST85ZF) in front of the two HDDs to make sure some air gets blown onto them rather than just pulled over. (Also, in the time it takes me to rewire all that shit, I allow the HDDs to cool off by my window )
I pop them back in, plug the power cord back in, and turn on the PC.
Hmmm... seems I forgot to note which drive was hooked up to which sata port, and now the start-up BIOS messages (or whatever they're called) stop at the phrase "Verifying DMI Pool data........" Okay, so I shut down, unplug the PC, open it up and switch the drives. I try again, only this time it again stops at that same phrase but also blanks the screen after a few seconds of this. WTF?
I switch the drives again, and receive the first scenario. Switch them again and I get the second one where the screen blanks after a few seconds.
So at this point I figure that maybe since that one drive was formatted and Win XP set-up began copying files onto it, and then I possibly switched them after cleaning up the cables, it doesn't know how to resume .
Hmmm... Is there anyway to somehow start over or 'clear' the drives? Where do I go from here?
end EDIT
AMD FX-57
P-180b/182
rest not important
