Are there any reviews or other info of the HyperDriveIII out there?
I'm not sure if it's really new, poorly marketed, or just vaporware.
Sorry if this is an old topic, but I did try searching first.
manufacturer's info is at:
http://www.hyperos2002.com/?affid=19129
If it's for real, it just might finally be the perfect consumer level solid state solution. (Bootable, uses plain ol' DIMMs, doesn't use expensive integration to get the form factor down - it's a 5 1/4 drive, and it's only $698.25 (+ PP and VAT) - a steal as solid state devices go.)
The only review they link is at bhreviews (which I'm not familiar with), and it's under construction...
http://www.bhreviews.co.uk/Hardware/hyperos_systems_ltd.htm
