HTPC (Stage 1)
Tman
Ok guys....
I have always dreamed about having a HTPC and conection it to my big screen tv and etc!! And because my old pc is not the best for this at all I decided to Build one.
I am thinking about these parts:
Microsoft Windows XP Media Center 2005 - OEM $131
ATI AIW RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/CATV/VIVO, 8X AGP, Model "ALL-IN-WONDER 9800 PRO" $235
AMD Athlon 64 3000+, 512KB L2 Cache, Socket 939 64-bit Processor $151
Seagate 200GB 7200RPM SATA Hard Drive, Model ST3200822AS,$133
But I dont know if I should get:
Corsair XMS Extreme Memory Speed Series 184 Pin 512MB DDR PC-3200 - OEM $99
OR
CORSAIR XMS, Xtra-Low Latency 2-2-2-5, 184-Pin 512MB DDR PC-3200, Model CMX512-3200XL $139
And I Dont know if I should get this Either or go Something Elce?
Samsung 16X DVD±RW, Model TS-H552B/WBCH Black, $56
Also What Mother Board should I go with and is there any good Flopy/Midea Readers out there that you would suggest?
I Was also thinking about getting this switch
xoxide_1824_16813867
linkey
Also maybe a Drive Cover Like this-
xoxide_1824_63355707
Linkey
Posibly this fan-
xoxide_1824_62647620
Linkey
Specifications:
Dimension: 80x80x25 mm
Air Flow: 31.7 CFM
Speed: 2700 RPM
Noise: 28 dBA (Ultra Quiet)
Voltage: 12 VDC
Current: 0.13 A
This Lighting Thingey :]
xoxide_1824_74674832
Linkey
Regular Fan Grill
xoxide_1820_12226245
it is going to be painted black
Thanks Guys :]
the XL will overclock better, if you will be doing that. otherwise, doesn't make much difference.
p.s. - host thine own pics;)
