HSF help for mATX tower
empower64
Hey guys, ive been looking for a good HSF combo for my SFF system but my problem is that my case is pretty narrow at 7 inches, at least in my opinion. here is the link to the case http://www.apevia.com/ProductsInfo.asp?KEY=X-Qboii-BL/500
Ive seen alot of you guys like some of the Silverstone HSF but im not sure they will fit in my case since the height needs to be under 7 inches MINUS the thickness of a standard 120mm fan attached to the side of the case that hovers over the HSF. so any thoughts? I want to get my q6600 G0 to 3.0-3.4...so i need to get decent air to it to make sure my temps arent a problem.
7 inches is plenty of space for the NT06. It is only 78mm high, and 7 inches is almost 178mm. I would get the NT06-Evolution if you are planning on overclocking, but even so I am not sure it would be up to the task. Might get some better input though.
ya, i went and looked at that and the scythe ninja mini...im pretty sure im going to purchase one of those or the coolermaster hyper tx2 sometime this week.
