HP xw9300 Temps
Brad900
I have a HP xw9300 which consists of 2- 2.4Ghz Opteron Chips, with SLi'd Nvidia 7800 GTX's 2- 74GB Raptors as well as a 400GB Storage drive. Nothing overclocked, just the factory settings.
Lately I have noticed a bit of fan noise coming from my case- but thought maybe I was just being sensitive to the noise since there was no other noise in the apt.
I installed SpeedFan and am getting a constant reading of 51C off of each processor while the system is at "rest".
Should I be concerned that I am running hot? Or is that temp whithin normal parameters?
Yes I am going to be the first one to post. I will tell you what everyone else is going to tell you. You are screwed buddy. You do realize that temp is over like 100 degrees man. I hate to tell you this but your computer is going ot blow up.
Is the rig stable? If so I would not worry about it. I spent too many years worrying about temps.
It all depends on your Load Temps. Try running a couple things that are really tough on your computer (prime 95?) and report back :).
