HP = Proprietary PSUs?
Sovereign
Can I stick a regular, industry-standard PSU such as this Fortron into an HP Pavilion a720n? Or does HP use weirded-out PSUs like Dell used to?
In other words if the plug from my PCP&C 850 fits then this should work with the aforementioned Fortron?
This PC was built/purchased in 03/04...usually proprietary stuff has a power cable that won't fit a standard PSU, nor will a standard PSU cable fit the proprietary power supply. The PC Power and Cooling cable fits....so I hope this works.
