The 2824 spins down the fans quite a bit, but there's definitely a constant whine. I have mine in my bedroom and couldn't sleep with it. The fans are quite easy to replace. I bought 3 new 40mm fans and they fit quite well. I did have to rearrange the wiring of each connector, but it was pretty straightforward. If the fans are too loud for you that's always an option.
I know this is very subjective and vague, but if you had a bedroom next to yours and you put it in that room would you still hear the switch with the doors open?
You could probably hear it, but you'd need to listen for it. If it turns out its ever too loud three of these will make it whisper quiet and they keep it cool enough for my uses. All you need is a torx driver and to pull rearrange two wires on each fan (the speed pin is in a different place).
If your worried about noise go with the 1810. Its works great, and makes no noise at all. Another nice thing is you can turn off the lights on it so you don't have strange glowing lights in the room next to you.
I beleve it supports almost everything you want in an L2 switch.
Posted via [H] Mobile Device
Yeah, the 1810 is my other option, but it's pretty much a web GUI only layer 2 "lite" switch. No STP or 802.1x, both of which I want to use/test/learn. I'd also like to get more into using NAP in Server 2008.
I think I'll just bite the bullet and go with the 2824. If it's too loud, I'll look into sound-proofing my rack.
Riley
