How's My Overclocking
abledon
:rolleyes: Need some friendly advise. If you could change any settings here to get more speed what would it be? I don't want to fry the system but I still want to get as much raw power out of it as I can. :p
Soyo Dragon Ultra Platnium
Motherboard model KT400-8235,
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 08/17/2004
Chipset VIA KT400 (VT8377) rev. 0
Southbridge VIA VT8235 rev. 0
Nanya Technology DDR-SDRAM PC3200 ( 400Mhz ) 512 Megs ea. ( 2 Sticks )
Aslyumn GeforceMX 4000 Video Card with 128 Megs of DDR Ram Core Clock 275Mhz
DiabloTec 450 Watt PS
Volcano 12 CPU Cooling Fan
4 Additonal 80MM Case Fans
2 WD 200 Gigabyte HD's with 8 Meg Cache
CMOS PIN RESET
AMD Athlon XP Barton Core 3000+
Clock Multiplier Automatic
DDR Voltage Default
CPU Clock Speed 1300
FSB Frequency 200Mhz
Bus Speed 100Mhz
Module 0 Nanya Technology DDR-SDRAM PC3200 - 512 MBytes
Module 1 Nanya Technology DDR-SDRAM PC3200 - 512 MBytes
CAS Latency 2.5 Clocks
Ras to Cas 5 Clocks
Ras Precharge 3 Clocks
Cycle Time ( TRAS ) 7 Clocks
2nd. Boot ( No CMOS Reset )
Clock Multiplier 13X
DDR Voltage Default
CPU Clock Speed 2166Mhz
FSB Frequency 166Mhz
Bus Speed 333Mhz
Ras to Cas 5 Clocks
3rd. Test ( No CMOS Reset )
DDR Voltage 2.7V
CPU Clock Speed 2300
FSB Frequency 177Mhz
Bus Speed 354Mhz
Ras to Cas 5 Clocks
*** Please Note
Unless stated above otherwise all other BIOS settings are currently set at there default values.
In your last setup, you've got a fsb of 177 and multiplier of 13 to get to 2300 mhz. From what I've read, you should be going for a lower multiplier and a higher FSB if possible. why not a 200x11.5 to get to the same 2300? From what I've seen, those numbers should be easily attainable with this processor.
I'm pretty new to overclocking though so take what I say with a grain of salt.
Nforce2 is the only way to go for the SocketA platform.....i order you to go to newegg right now any buy a Nf7 NOW! (or An7 is you got the little extra $Bling$)
:D :D :D
2300 Mhz isnt too bad, considerign the CPU cooler, Goodjob dude...
