Let me rephrase that, how do I tell if the copy of XP Pro that is installed is an OEM, Retail, or Volume license copy. The general tab does not appear to give me that info.
this prolly doesnt really help, but if you have a sticker on the case you can look at taht and it will tell you.
Other than that, ive never really had to look.
if you look at the box i circled in the Product ID it says OEM (I have an OEM copy )
Chances are you wont be able to tell a difference between Retail, VLK, or Corp apart from actually trying to install with the key with the appropriate CD for that license
